Can't pinpoint what sounds like a bearing issue!
Old Feb 13, 2023 | 07:43 AM
  #31
MJR1970's Avatar
A bad tire cam make a roaring noise. Always check the tires first before replacing parts due to noise.
The noise has been going on a long while, just got a new set of tires recently, no change.
Old Feb 14, 2023 | 01:44 PM
  #32
Have you had a chance to change the axel?
Old Feb 15, 2023 | 04:26 PM
  #33
PulpFriction's Avatar
What size tires are on it?
Old Feb 15, 2023 | 09:59 PM
  #34
MJR1970's Avatar
Not yet, have appt to get it done next Tuesday!
Old Feb 15, 2023 | 10:14 PM
  #35
MJR1970's Avatar
205/60R/16
I have ran this tire size for several years.
Old Feb 21, 2023 | 05:57 PM
  #36
MJR1970's Avatar
Originally Posted by MJR1970
Thanks! I wondered if it would be difficult to remove if it didn't come out with the old axle.
Man, I had it at the shop today, mechanic said I ordered wrong axle. Said old one has a female end that goes into transmission. I told him it was a stub that comes out. He said no. So I just had him go to the parts store and get one. I was at work and didn't feel like arguing.
Old Feb 21, 2023 | 06:02 PM
  #37
MJR1970's Avatar
You say you've replaced the passenger side hub twice recently. Oldblue's suggestion of driver side hub should be considered.
Welp guys, shop replaced axle, mechanic drove it, said it was definitely driver side bearing. He replaced driver side and I'll be damned, that was the bad one. Crazy though because it was completely ass backwards from how a bad bearing normally behaves when swerving and shifting weight to opposite side. Oh well, lesson learned, if it sounds like a wheel bearing, it probably is! 🤣
THanks for all the help bro's!
Old Feb 21, 2023 | 06:21 PM
  #38
So another mechanic who doesn’t know jack! You have to remove the stub shaft! Detroit Axle 986M-AX eliminates the stub shaft and cup seal , I just installed one in my 2011.
https://www.chevyhhr.net/forums/driv...mission-66019/
Old Feb 21, 2023 | 09:30 PM
  #39
Well which part was replaced? The Axle shaft or the wheel bearing (hub)?
Old Feb 21, 2023 | 10:59 PM
  #40
MJR1970's Avatar
I told him that but he was adamant that I was wrong. I couldn't believe he didn't know. Maybe he just wanted to get another one just for the mark-up or he thought it would be a pain to get the stub out. Either way, I'm glad to be done with this. And I can send the other axle back.
