cleared codes
Old Jun 26, 2018 | 03:19 PM
Cliffs51's Avatar
Update: Just got back home to Ocala Natl Forest averaging about 60 mpg on secondary roads. MPG average on dash-36.5
Old Jun 26, 2018 | 04:13 PM
If you remove the throttle body , do not move the throttle plate manually, the little plastic gears can be stripped and destroyed very easily.
Use the correct throttle body cleaner not brake or carburetor spray.
The wire connections are finicky, leave it connected and move the throttle body very carefully while cleaning it.
Old Jun 26, 2018 | 04:25 PM
Cliffs51's Avatar
Thanks for the info. Maybe since im getting 35 to 36 mpg at 60 mph I shouldn't mess with the throttle body anyway. 😁
Old Jun 27, 2018 | 02:46 PM
I wouldn’t.
Old Jun 27, 2018 | 03:15 PM
Dirty throttle body has more to do with the butterfly sticking than MPG. Throttle body only looks like a carburetor.
Old Jun 27, 2018 | 03:35 PM
Cliffs51's Avatar
"If it ain't broken don't fix it" 😁
Old Jun 28, 2018 | 06:58 AM
Cliffs51's Avatar
Ive read on other posts here that if the cold air intake tube is too big on a custom cai system it will throw a code. So my reasoning says that if the cai tube is broken open too much air is getting in and causing a code.
Old Jun 28, 2018 | 08:52 AM
Don't count on it. Oiled filters, yes.
Old Jun 28, 2018 | 09:00 AM
I’ve got an aftermarket CAI, and lightly oiled air filter. No codes.
This K&N FIPK kit draws cold air in through the OEM woolly worm.
This dryer vent tubing was for a double snorkel type intake for extra air, I ran this for a few years , with a drop in K&N lightly oiled air filter, no codes
Old Jun 28, 2018 | 09:35 AM
Having a severely damaged wooly worm would raise intake air temperature, not sure, but maybe could cause a code. But having a larger intake hose, being before the MAF sensor, should not cause any codes.
hvrod
Jan 8, 2018 06:32 AM
Martial Law
18
Apr 7, 2011 12:02 AM
z28nate
Dec 10, 2008 11:06 AM
scaleguy
Mid Central
13
Apr 13, 2008 08:23 AM
kizzme
Aug 31, 2007 09:53 PM
