Engine replacement
Engine replacement
So I brought another Hhr, this is my 3rd for my company and they are great cars. This one has a blown engine (valve drop or timing jump). Anywho I have a replacement engine with 76k miles. What is the recommended items that I should change while the new engine is not in yet? Timing chain? Water pump?
i don’t want to go crazy, I’m looking to get 3-4 years out of it or 60k miles.
2011 Hhr 2.2 LS. Currently says 67k, those damn valves.
Timing and balance shaft chains, guides and tensioner and a new water pump, Cloyes kit 9-4201SAWP and thermostat AC Delco 131-158. Then a new upper motor mount, and don’t forget a replacement upper timing chain bolt, Dorman 917954 and four new AC Delco 41-103 Iridium spark plugs.
If you’re ordering parts don’t forget our discount code at RockAuto!
https://www.rockauto.com/en/moreinfo...=8165228&jsn=3
X2, yes that bolt!
RockAuto website
and their discount code
https://www.chevyhhr.net/forums/www....ad.php?t=61707
RockAuto website
