Engine ticking while running
Old Sep 6, 2024 | 07:36 PM
Consolidated threads
Old Sep 6, 2024 | 10:07 PM
Gearhead1's Avatar
I would take the accessory drive belt off and crank it and see if it still makes the noise. If it does not then maybe alternator or a/c compressor making it or tensioner pulley
Old Sep 7, 2024 | 08:09 AM
[QUOTE=ScarletKnightrose;950400]
What is that in the bottom left of the picture ? The object with writing on it that looks like it shouldn’t be there ?
Old Sep 7, 2024 | 09:29 AM
Looks like a can of some sort. Probably this source of the noises
Old Sep 14, 2024 | 03:04 PM
ScarletKnightrose's Avatar
It's makeshift can for my overflow for the coolant. That does not have anything to do with the noise. It's all coming directly from the engine it's self.
Old Sep 14, 2024 | 03:32 PM
What was wrong with the original design of the coolant recovery tank? Hard to believe one from a junkyard would cost more than $5.
Has the water pump been replaced? The impeller has been known to disconnect.
Old Sep 14, 2024 | 03:41 PM
The original one on the car was badly damaged and right now its a temp fix till I can find one. The junkyards around me do not have any hhr's at the moment but I have been checking. The pump has not been replaced since I bought it. I do plan to replace it soon though to stay ahead of issues.
Old Sep 14, 2024 | 04:26 PM
FYI. If you end up finding the timing chain needs replacement, then replace the water pump while the engine is apart. The water pump is driven by the 2nd chain (balance shaft chain)
CC driver
Jun 16, 2021 07:04 PM
blue car
Nov 7, 2014 05:29 PM
jprios
Sep 30, 2014 11:27 PM
SwaintaN
Mar 25, 2014 12:16 PM
SLEON
May 13, 2012 08:58 PM
