Engine Tune Up Questions
Old Feb 22, 2023 | 10:39 AM
  #31
PulpFriction's Avatar
Originally Posted by rose359
1) The exhaust is loud. Could a bad O2 Sensor be causing the exhaust to be loud?
No. But an abnormally loud exhaust is a leak. If the leak is upstream of the O2 sensor, the computer can draw faulty conclusions about the a/f mixture. All leaks in the exhaust system are hazardous and should be fixed, but leaks upstream of the O2 sensor will cause engine problems, too.
If the leak is a broken flex pipe, you may have a bad motor mount, in case no one mentioned that yet.
Old Feb 22, 2023 | 11:00 AM
  #32
rose359's Avatar
No. But an abnormally load exhaust is a leak. If the leak is upstream of the O2 sensor, the computer can draw faulty conclusions about the a/f mixture. All leaks in the exhaust system are hazardous and should be fixed, but leaks upstream of the O2 sensor will cause engine problems, too.
I had not yet heard the concern regarding the motor mount. Once we get past our current winter weather, we will be able to get a good look at the whole exhaust system. Thanks for your help!
Radco
Maintenance and Upkeep
16
Aug 16, 2019 09:16 PM
2005HHRauto
2.0L Performance Tech
Jul 3, 2016 10:44 AM
prater_1
19
Aug 6, 2014 07:26 AM
Walikah
Aug 21, 2013 01:44 PM
kishasara
Oct 13, 2010 09:20 PM
