Good luck with the taillight bulbs.
Old Aug 14, 2016 | 03:11 PM
Ashes25's Avatar
Originally Posted by whopper
If the housing is still usable, you have to pick the remains of the bulb out with whatever tool works for you. It most likely will come out in pieces.
If your problem is that the housing is melted such that the new bulb won't go in............ you need to get a new housing.
I was able to get the blub out but it broke coming out. I can't push the new blub into place though
Old Aug 14, 2016 | 03:13 PM
I don't know what else I can suggest - did you get all of the broken bulb out?
Old Aug 14, 2016 | 03:28 PM
Ashes25's Avatar
It seems like it yes. But it looks like part of the opening where the blub goes in is melted.
Old Aug 14, 2016 | 03:31 PM
Ahhh, well it's pretty obvious.............. you have to buy a new housing.
Old Aug 14, 2016 | 03:45 PM
Ashes25's Avatar
So not to sound totally stupid. But what if that? This is my first car
Old Aug 14, 2016 | 03:49 PM
  #26
The part that is broken, that is supposed to hold the bulb.
1. bulb holder
2. bulb
3. housing
Old Aug 14, 2016 | 03:55 PM
  #27
Just to give you an idea of the parts available and what they're called.
Old Aug 14, 2016 | 04:09 PM
  #28
Ashes25's Avatar
Attachment 19860
It's in the lamp part. It looks like the blub melted it. I'm hoping I can replace it through the front
Old Aug 14, 2016 | 04:17 PM
  #29
No. See post #26. The three nuts hold the bracket.
Old Aug 14, 2016 | 05:58 PM
  #30
Fish goes blub. This is a bulb.
So you got into the cargo area, removed the access panel, rotated the bulb holder, removed the bulb/bulb holder assembly from the housing, then removed the bulb from the bulb holder. At some point the bulb broke, and you're not sure if you got all of the old bulb out of the bulb holder. Is all this correct so far?
So is the problem that
1. You cannot get the new bulb into the bulb holder? or
2. You cannot get the new bulb/bulb holder assembly into the housing?
