Heating and air conditioner
Old May 22, 2014 | 07:32 PM
Charlottesalami@yahoo.com's Avatar
My a/c blows hot air. What can I do to get that fixed. What could be wrong with my a/c???
Old May 22, 2014 | 07:45 PM
to the forum!
Well it sounds like your A/C "dumped its charge", or in other words, the refridgerant charge is low preventing the compressor from engaging.
Your best bet would be to find an auto air conditioning shop and have it checked. They'll be able to accurately diagnose the problem.
Stay away from those "A/C Repair In A Can" products you see advertised on TV. They can do more harm than good and make a small repair bill into a big one.
Old May 23, 2014 | 06:18 AM
The other thing is the engine coolant temp and level. If your check engine light is on, get it read; Probably need a new thermostat.
Give the search box a try, there is an overwhelming amount of info about "no a/c".
Old May 23, 2014 | 10:24 AM
Doc brown's Avatar
It could be several things, blown fuse, blown relay(s), bad compressor, low refrigerant, leak in compressor, condenser, or a line somewhere, or a blockage in the system. Unless you have the equipment and some experience in troubleshooting this you are best off taking to someone qualified that has the right equipment to diagnose it.
rager24
May 12, 2014 08:40 AM
o6designs
Feb 5, 2011 12:03 PM
FireBall!XL5
Jan 28, 2011 01:01 PM
jmarines
15
Feb 11, 2009 05:21 PM
Retro1949
Jul 24, 2008 08:27 AM
