How to change your own oil.
Old Feb 19, 2013 | 07:11 AM
  #221
solman98's Avatar
All this talk about the o-ring and mine's still running the original....
And no leaks..
Old Feb 19, 2013 | 10:03 AM
  #222
B.Diggity's Avatar
Wow. Thats askin for failure :p
Old Feb 19, 2013 | 10:08 AM
  #223
solman98's Avatar
Gasket is still soft and plyable with no scuffs or anything on it. I see more people having issues after they change it or overtightening the cap. I'm the only one that have ever taken it off.
Old Feb 19, 2013 | 11:59 AM
  #224
Snoopy's Avatar
Again, Diggity, if you research my previous referenced post, GM states the filter "O" rings are designed for the life of the vehicle. And most dealers purchase their replacement filters in bulk. That method does not supply the "O" ring. Just think of all the filters that are installed without the new ring.
Now understand, I AM NOT saying you're wrong for changing it.....it obviously won't hurt. But to criticize someone for not doing it, when they experience no problems, or see no damage, is not valid...IMO. Especially when written documented evidence provides the contrary.
A lot of bad info here and misconceptions. I wish I could reveal the contractual job I just finished for GM. You would be amazed at the results.
Like solman, I still have my original installed also. But I do have an extra, just in case.
Old Feb 19, 2013 | 12:12 PM
  #225
B.Diggity's Avatar
I ment bragging about it. :p my luck, everytime i brag, it fails. Lol
Old Oct 29, 2013 | 02:28 PM
  #226
Bearhawk's Avatar
Thanks for the great post. Awesome information.
Old Nov 14, 2013 | 11:44 PM
  #227
coachpsr's Avatar
Unhappy Resetting the oil life.
I went by the Manual and turned the key without starting it, press the Info and reset buttons at the same time nothing is happening. I'm thinking my reset button is bad. I know my Info button works. Help needed.
Old Nov 14, 2013 | 11:56 PM
  #228
Do it the "Easy Way" turn key on (without starting it) , Depress gas pedal 3 times & it will reset to 100%
I've been doing it that way since I got mine..
Old Nov 15, 2013 | 11:09 AM
  #229
Snoopy's Avatar
Just to add.....the gas pedal needs to be depressed 3 times in 5 seconds. I've witnessed people who kind of hesitate for expectations, and it didn't change.
Old Nov 15, 2013 | 10:36 PM
  #230
Snoopy- Thank You Sir..
