How to change your own oil.
Old Feb 13, 2013 | 12:58 PM
  #211
Old Lar's Avatar
Fram filter has the o-ring.
Old Feb 13, 2013 | 01:01 PM
  #212
Snoopy's Avatar
^^^^Depending on when it was purchased....made of the wrong material.^^^^
Old Feb 16, 2013 | 09:56 AM
  #213
alexrckid's Avatar
used a fram ultra last week.....with the "orange" o-ring........no leaks..all is good. i think that some of the leak issues are cause of not lubing the ring...dont know, just know that no matter which brand of filter that i've used over the years on the HHR(purolanor, fram, mobil 1, bosch), that i've never had and leaks, at all......
Old Feb 16, 2013 | 10:06 AM
  #214
B.Diggity's Avatar
Biggest cause of leaks are over torq when screwing in the filter lid and not replacing the gasket/inproper setting of the gasket. :) other than that havent seen one leak
Old Feb 16, 2013 | 12:25 PM
  #215
Snoopy's Avatar
Nope. Biggest cause of oil leaks in the filter area is improper gasket material by aftermarket filter manufacturers. That's why I posted a service notice by GM/Chevrolet, about it. Do a search you'll find it.
Old Feb 16, 2013 | 12:44 PM
  #216
B.Diggity's Avatar
Lol well the only cars ive seen come in leakin, are canisters that were put on wrong or never replaced so it broke apart and leaked.
Cts and camaros are the two biggest offenders.
Old Feb 17, 2013 | 10:21 AM
  #217
rainmanva's Avatar
i may at some point decide to start changing my own oil the price between the oil and filter and what my mechanic charges is not all that much. and to it can be pain. i gotta buy ramps etc. just not a dramatic enough cost savings to justify doing it myself.
Old Feb 18, 2013 | 07:24 AM
  #218
Old Lar's Avatar
I just use a small jack to raise the HHR high enough to reach under to get at the drain plug with a ratchet. No need to crawl under the car, just reach under.
Old Feb 18, 2013 | 08:38 AM
  #219
B.Diggity's Avatar
You can go to a pawn shop and get a 3ton jack for like 40$. Once you do it a few times, you start saving. Plus you know what you did, and not have to trust someone you dont know as often. Plus some lube shops hire newbies and dont always train very well. :p
Old Feb 18, 2013 | 04:13 PM
  #220
jerry455's Avatar
I have always done my own maintenance and enjoy doing it.
