I normaly use everything Meguiar's on my cars !
Old Jun 24, 2011 | 01:00 PM
Snoopy's Avatar
Originally Posted by nacademus
Ever use Zymol?
lol-oh yeah, its almost ten grand for the stuff... lifetime refills though.
That's because PURE Carnauba is the worlds most expensive wax (look it up, if you don't believe me). It's kind of a good chuckle, when people say they use XXX brand and it's 100% carnauba wax. But they pay $15-20.00 for it. Yeah, right. The can/bottle says 100% carnauba wax....it means they USE 1% of the 100% carnauba wax.
Old Jun 24, 2011 | 01:09 PM
nacademus's Avatar
http://www.meguiarsonline.com/forums...ad.php?t=25310
I just crapped myself.
The MYTHS of Carnauba wax
Hopefully this thread will help clear up some misconceptions about carnauaba wax as it applies to the automotive detailing industry.
Myth One: My car wax is 61 percent carnauba wax by volume!!! It's the best (and only cost 2g's)!!!
Unlike the FDA which requires independent studies to make sure the labels on food are accurate, detailing companies basically answer to themselves (and their customers).
Carnauba wax is harder then concrete in natural forum must be softened with solvents. California VOC regulations have limited the aggressiveness of the solvents that can be used, but it is safe to say that no more then 28% of the wax can be carnauba wax. So how do we arrive at this number (60% or more?)
Carnauba wax can be measured many ways but it should be measured in wet volume (that is the carnauba wax should be melted into a liquid forum). In general carnauba wax is shipped in very fine flakes, which would be there DRY volume.
An example would be to fill a 20 gallon garbage can half way up with feathers, then fill the rest up with water. Because of the light density and air gaps of the feather you could potential fill the rest of the can up with 16 gallons of water (so that only 1/5 the volume is actually feathers) and proclaim that it is 50% feather by volume (if you don't state that it is dry volume) where scientifically you would be at 20%.
Also, measuring product by weight (and thus density) is more accurate. Keep in mind that the oils and solvents added to the carnauba are usually two to three times heavier then the melted carnauba, so by weight the figure would drop to 10% (or so).
It’s a play on marketing and in my opinion false advertising.
Myth Two: My wax is 100% carnauba.
Well it cannot be more then roughly a 1/3 carnauba otherwise it would be like a block of concrete. However, if we look at the percentage of the wax in the product (assuming that no other waxes are blended in like bee's wax) then it is possible to have 100% of the wax content being carnauba.
Myth Three: The carnauba in my wax is #1 Ivory White Pure Carnauba!
Automotive waxes feature #1 Yellow Carnauba. This is the highest form of natural carnauba wax and even then it is not an expensive product. "White" or "Ivory" carnauba wax does not exist, period. It is yellow (different shades of yellow depending on age) and it is either #1 or it isn't. Micro carnauba (finely milled) can look white, but in general the carnauba wax is whitened by a bleaching process or by tumbling the flakes in paraffin wax.
Myth Four: More carnauba is better
Maybe. Carnauba wax isn't exactly super reflective in natural form. It has a filmy, slightly opaque look. Medicine and gummy bears are both encased in carnauba wax and neither has a mind blowing, jaw dropping look. It is the silicone, oil, other waxes, and solvents added to the carnauba wax that produces the shine, wetness, gloss, etc. Carnauba wax does benefit from an optical illusion called "jetting". This slight distortion in the reflected light is what creates the illusion of wetness or depth on the surface, which is desirable for many people.
Keep in mind that only a small part of the look the wax produces is from the actual content of the carnauba. The rest is from the other ingredients. Also, the wax itself is rather cheap, so you end up paying more for a product that boasts of using the cheapest ingredient in the main formula.
Manufacturers spend a lot of money researching the proper amount and what type of ingredients to mix into the wax solution to achieve the desired results. If you ask your manufacturer how much carnauba wax is in the product, a good response would be enough to get the exact look and application feel to get the job done.
Myth Five: My wax is so high in carnauba that I have to warm it with my body heat and apply it by hand!!!
Carnauba wax melts around 160 degrees F. unless you are The Human Torch, you are not melting anything. When mixed into a solution that offers more durability, the melting temperature is generally raised. Certain solvents will react with human oils and soften however. Besides if your wax melts at 98.7 degrees, imagine what happens when you pull your car in the sun!
Myth Six: My wax uses natural ingredients!
Muriatic Acid and cocaine are natural ingredients as well. So is sulfuric acid.
Myth Seven: My wax cost 2g's but I get a lifetime of refills and it has all the myths listed above. It’s a great deal!
Most waxes cost between 2 to 5 dollars to make and bottle. (5 dollars being VERY expensive). What we cannot account for is the R and D that goes into the product, as well marketing, etc... However, if you pay 2'gs for a 5 dollar wax (assuming it is very expensive to manufacture), receive a 100 dollar container, and life time refills, you are not getting a great deal by my simple, mid-western logic. That means you would have 1900 dollars in product that you would have to refill 380 times to break even (minus the shipping costs each time).
No more than 28 percent...
Old Jun 24, 2011 | 04:02 PM
davidjb's Avatar
for the dash, rubber and plastic I use 303 aerospace protectant its usually sold at speed shops or truck cap stores. more of a natural shine not greasey and uv protectant
Old Jun 24, 2011 | 06:22 PM
Snoopy's Avatar
^^^^^ good stuff ^^^^^^^
AND does NOT attrack dust !!
Old Jun 24, 2011 | 10:09 PM
87silver's Avatar
I have 7 vehicles and a motorhome ranging from model year 1964 to 2008. All are automotive eye catchers. I use whatever good stuff that is on sale, be it Meguiars, Mothers, Eagle1, etc. I never go for the dollar store brands though.
Old Jun 24, 2011 | 10:57 PM
pipes's Avatar
I have a block of pure carnauba wax I use for wood working and the stuff is as hard as any rock you ever saw no way you could put it on a car IMO anyway . So the stuf they claim is pure can't be it has to have a pile of adidtives to soften it IMO anyway .And yes it does come in flakes normaly you can buy pure in flakes or some places melt it into cupcake tins and sell the blocks .
When I want to break a piece off a block of pure I use a hammer to crack it off thats how hard it is ! never saw any white just yellow diffrent shades thou .And a tiny piece on a buffing wheel will last a long long time .. I mostly use it on tobacco pipes when I restore them but since I quit doing them a yr or so ago haven't used any .
Anyways thanks for all the info folks !I have some Mag gold left as soon as thats gone iam gona try the synthetic and see how it does ! But seeing as I wax mine every month doubt it makes much diffrence !
Old Jun 25, 2011 | 05:27 AM
hyperv6's Avatar
Most waxes that claim to be pure Carnauba is not 100% It is close enough to claim but has softerning agents to make it workable and is till the hardest protection for any car. The new Mirco technology wax like Nex Gen works near as well.
The meaning of pure wax has more to do that it contains no polishing or cleaning agents like a one stage wax. Generally with a pure Carnauba you need to use a polish or several polished to attain the shine and then seal it with the carnauba wax.
You have to be an idiot to use true 100% virgin wax. If you really understand wax it is understood what they mean buy pure. That is why they don't claim it to be 100%. Regardless it one of the longest lasting and most durable ways to seal in a paint. It also makes for the best way to keep the finish look right with a proper detailer.
I show a black car and year round drive a black car daily. I know what it takes to keep them in show condition and win at national events. The fact is there are a lot of good products out there if used properly in combination with other products. To day one is better than another is short sighted. A good shine is more about prep and the work you put into it. Often the amount of work is what is effected with come products. Some work easier than others and some last longer than others.
There is no one right answer here but just what works for you and being informed.
Waxes are like carbs and bad paint. I see someone put on a new carb right out of the box and never rejet it. They think the car is 100% better as it now wants to run much better. If they only take the few extra steps to tune it they would run even better. Too often because of the missed extra steps many leave a lot of better shine on the table.
Lucky
Oct 4, 2013 10:01 PM
TkHHR
Dec 24, 2008 08:04 AM
mitzkity
Feb 21, 2007 09:26 PM
