just picked up 2006 HHR
or a air tool and compressor for the bottom nuts, and everybody forgets to mention a drift and hammer to get those same bolts out.
Only issue I had was replacing sway bar links after I screwed mine up using the wrong size wrench trying to keep the dang ball end from spinning. I would recommend replacing the link ends with the struts anyway.
If you replace the links with the struts it is one less bolt to take off :)
