just picked up 2006 HHR
Old Mar 31, 2014 | 06:21 PM
Originally Posted by mongo
I have had zero issues with my 08 Panel that are not normal maintenance. If you need to replace the struts, get the 'quik-strut' with the spring pre-installed, makes it a 15 minute job that can be done in the driveway with hand tools.
Hand tools and big forearms or a air tool and compressor for the bottom nuts, and everybody forgets to mention a drift and hammer to get those same bolts out.
Old Mar 31, 2014 | 09:26 PM
mongo's Avatar
Did mine with hand tools. Only issue I had was replacing sway bar links after I screwed mine up using the wrong size wrench trying to keep the dang ball end from spinning. I would recommend replacing the link ends with the struts anyway.
Old Apr 1, 2014 | 06:04 PM
King Aires's Avatar
If you replace the links with the struts it is one less bolt to take off :)
Old Apr 14, 2014 | 10:18 AM
scbill's Avatar
Get the links with grease fittings on them, I got a set off Ebay for $26. If it's already "klunking" replace the swaybar bushings while you're at it(easier with the links loose/off.
Bill
onequicktang
2.0L Performance Tech
Nov 24, 2014 08:55 AM
Mike Lightkep
Aug 24, 2013 09:22 AM
bf4cm28
Apr 27, 2011 08:34 AM
BobZ06
Jan 15, 2009 07:34 PM
Graigz28
Aug 6, 2007 09:17 AM
