LED rear brake turn bulb recommendations
I did a few searches on this forum, & found threads on LED headlights, but none for LED rear brake & turn bulbs.
Does anyone have any recommendations for bulbs that have worked for them? Ebay is loaded with cheap ones, I question if those are any good. Sylvania seems to make a few different ones, one marked "off road use only". If you installed LED's in the rear, any problems? No resistors needed, & the flasher still worked correctly?
Thanks!
Thanks!
djmoose
0
Jun 15, 2008 08:18 PM
