Lower control arm, rear bushing bolt/pin
Old Jul 19, 2023 | 01:29 PM
Originally Posted by FirstGenHHR06
Ok so I have the green puce but it's not green and no threads. Also the old bolt is in 3 pieces I got a new one from the dealership, but now it's the mater of putting that but back in (that has no threads) without putting it on the lift cause my man's vehicle is on it with no tires
Puce is a color that is not green. That first sentence just makes no sense.
Old Jul 19, 2023 | 02:42 PM
Let’s go with typographic error, the green puck? Or green piece.
Old Jul 19, 2023 | 02:44 PM
I think he meant “green piece”.
Old Jul 19, 2023 | 06:54 PM
They're the ones trying to save the whales, right?
Old Jul 20, 2023 | 06:31 AM
No, they’re Green Peace.
Old Jul 20, 2023 | 06:46 PM
PulpFriction's Avatar
Close. Greenpeace. One word. A bit more than saving whales. Have a look.
I'm thinking about going to the drawing board (literally, I still have one, even tho I don't use it or CAD either much anymore) and try to design a solution for spun cage nuts. Anyone have any thoughts as why a cage nut was used in the first place?
Old Jul 21, 2023 | 06:08 AM
It’s inexpensive.
fastsuv came up with a good solution, and it worked bolt , washer then nut.
Old Jul 21, 2023 | 07:07 AM
Originally Posted by Oldblue
It’s inexpensive.
Yeah, but so is a weld nut. Someone thought it needed to float. I don't see the need, unless they thought they couldn't hold the tolerance to the front guide holes well enough to avoid assembly problems.
...fastsuv came up with a good solution, and it worked bolt , washer then nut.
Gotta look that up. I was thinking just a strategically shaped tapping plate that would slide in place and can't rotate no matter what, no weld required. But I've never had to deal with this so I don't know the territory. Also not used to having no reference drawing to work from.
Old Jul 21, 2023 | 08:31 AM
A slide in plate with a nut welded to it would work.
Old Jul 24, 2023 | 09:25 PM
I like that. Lighter, and might be easier to install.
