maintance on low milage hhr
Old Jan 5, 2014 | 02:53 PM
ponchogeezer's Avatar
hi group. I have not been able to drive for the last 14 yrs.I bought my wife an hhr in 09.It now has under 15,000 miles.Being 5 yrs old I now question what needs changing and what is still good]belts,hose coolant ,ect]What says all you maintance guys? thanks phil.
Old Jan 5, 2014 | 04:44 PM
The coolant is due for a change at 5 years, that's not mileage dependent. Dexcool has a service life maximum, and you should stick to it, changing to a regular Glycol based coolant(the green stuff), requires extensive and intensive flushing of the cooling system.
Other than that, the serpentine belt should be inspected for cracking and dry rot, the oil should be changed if it hasn't been done for a while(corrosive contaminants build up over time), and the hoses should be checked for bulging or deterioration.
Old Jan 5, 2014 | 04:49 PM
When you get done with all that, I would adjust them self adjusting rear brakes........
Old Jan 5, 2014 | 04:55 PM
Good point Sam, along with adjusting the rear drum brakes, you should check the front calipers to make sure they're free to move on their slides.
Old Jan 5, 2014 | 08:25 PM
To keep the wife happy, go ahead and replace that 5 year old cabin filter.
Old Jan 6, 2014 | 02:09 PM
Welcome to the site, use the search widow to check out many threads for any other questions you may have.
Old Jan 6, 2014 | 06:32 PM
Lucky's Avatar
Welcome to the site. I agree with all of the above.
With such low mileage I would add a fuel cleaner to the tank.
I like seafoam but it's your choice.
I would also recommend to have the 5 yr old battery tested. Most part stores can test the battery for you for free.
puterfool
Aug 30, 2015 10:52 PM
Happy Jim
Fuel Economy - Hypermiling
35
Dec 30, 2010 09:01 AM
Mofo
0
Jul 14, 2009 12:38 AM
dpoll995
Oct 3, 2008 11:15 AM
Kev1964
Jul 13, 2008 05:56 PM
