massive dirt underneath the HHR
Old May 10, 2021 | 10:03 AM
ScareDe2's Avatar
Just bought a used low mileage 2007 HHR, oil treated every year the body is clean and almost free of rust, but underneath the car, I don't know where the guy spent his time with it but it's full of dark dirt and there is indeed some rust. I am hesitant to remove all this. What should I do? Carwash and new oil treatment?
Old May 10, 2021 | 10:05 AM
Engine shampoo , then car wash then oil spray
Old May 10, 2021 | 11:07 AM
Silverfox's Avatar
Not sure if anybody still does undercoating on cars and trucks.
They used to put them up on a lift and power wash the whole underbody before spray undercoating.
Do some calling around.
Ask each person you talk to for any suggestions.
When we were in Hayden Idaho the best car wash had you pay an extra $1 for an underbody fresh water spray to remove the road salt in the winter.
Not sure if it would remove heavy caked dirt ??
Silverfox
Old May 10, 2021 | 01:04 PM
Possible that most of what looks like dirt, is actually undercoating, with a layer of dirt on it?
Old May 10, 2021 | 08:51 PM
I'm seeing a lot of spray-on oil coating underneath places on the hot rod shows. That would certainly attract a load of dirt & get it very dark.
But that is 'supposed' to prevent rust. But the dirt might trap water & actually cause rust.
Old May 10, 2021 | 10:27 PM
Silverfox's Avatar
You don't show your actual location.
That could make a difference in whether you will be dealing with more salted and treated roads.
I saw a guy with a small pickup.. and his rig was jacked way up from the side so he could power wash 1/2 the underneath at a time.
It looked like he was a Mudder. It also looked as if he had done that before.
That might be a problem with the HHR and Jack lift points.
SF
Ronnie
Maintenance and Upkeep
26
Sep 23, 2020 01:56 PM
geg
2.4L Performance Tech
7
Jun 11, 2019 08:07 AM
Humberto Mendoza
23
Jul 24, 2018 07:00 PM
Titans2
Mar 8, 2013 09:34 AM
Wolfie
Aug 23, 2012 09:45 AM
