My key fob issues fixed
Old Jan 15, 2016 | 03:34 PM
a_bartle's Avatar
I had the same problem, I re-soldered mine and replaced the buttons with one I purchased from e-bay. The fob was working great, then it stopped working again. I took it apart, cleaned the contacts and once again it was fine. However, my son borrowed the car and reported that the key fob wouldn't work. Soooo, not really sure what the problem is, the battery clip is still soldered tight. I ended up grabbing my spare key fob (which works... for now) to use.
Old Jan 15, 2016 | 04:26 PM
Hey Art, try replacing the key pad, sometimes cleaning the contacts doesn't last long.
Old Jan 15, 2016 | 07:21 PM
aradmahogany's Avatar
Originally Posted by donbrew
There is also the "cigarette pack foil" fix; wherein you take the metallic foil a glue bits to the worn out carbon contacts.
HA I used this exact fix and it works perfectly!!!!!
Rikki Sixx
Mar 25, 2014 02:36 PM
wittdem
Sep 10, 2013 12:16 PM
maier748
Mar 27, 2011 09:54 PM
Gambler
Jul 3, 2006 10:12 AM
