Need an exhaust system-- suggestions?
Old Sep 9, 2023 | 07:43 AM
https://www.obd-codes.com/p0420
Exhaust leaks? Look at the list of causes and see if any apply to your exhaust
Old Sep 9, 2023 | 08:18 AM
Rocket Dawg's Avatar
No exhaust leaks. The O2 sensors are about 18 months old. No problems until the new system was put in and about 500-700 miles put on it. You tube suggests spark plug non fouler extensions. Is that my next project? I can imagine a new converter is already dirty with no engine changes. Do people put 2 of them on? or just the back one?
Old Sep 9, 2023 | 09:04 AM
https://www.chevyhhr.net/forums/2-2l...20-code-58413/
My adventure with O2 extender
it is always a possibility to contact the catalytic converter supplier and see about their warranty replacement.
Old Sep 9, 2023 | 09:20 AM
I'll get it up on the ramps today. There may be a possibility of the manifold to the cat flange bolts loose as I read to torque them to only 20 ft lbs. Seemed a little on the low side to me. But I'll start there. I'll have the extenders with me as well, they are fairly inexpensive and in stock at AutoZone. Simple enough to a least give it a try. . Keep ya posted and thanks for the reply.
Old Sep 9, 2023 | 09:24 AM
Will these do the trick if needed? 18 mm
https://www.autozone.com/ignition-tu...009/730544_0_0
Old Sep 9, 2023 | 10:01 AM
  #26
Should but might need to open them up to 1/2 inch hole so the sensor fits into it. I installed one of these longer ones
2Pcs O2 Sensor Spacer, M18*1.5 Spark Plug Non Fouler Catalytic Converter Cleaner Check Engine Light Fix Extension 45mm Length (Silver) (Type D) https://a.co/d/ga2awYV
Old Sep 10, 2023 | 11:18 AM
  #27
Checked system for leaks, all is good. Added the adapter and drilled it out. So far about 65 miles since and no code. Hopefully it's a cure.
Old Sep 10, 2023 | 02:43 PM
  #28
Fingers crossed!
Old Oct 5, 2023 | 08:54 AM
  #29
Almost a month and still running good and no codes.
Old Oct 5, 2023 | 08:58 AM
  #30
Ok, I can uncross my fingers, oh that hurts, such a cramp!
