oil change info
Old Jul 19, 2007 | 10:29 PM
Originally Posted by mrjuma
how do you know all these threads?
Knowing keywords in particular threads helps alot!
Originally Posted by Applenut
He used to be unemployed......
And that's a big help as well. Personal experience talking here.
Old Aug 27, 2007 | 05:58 PM
TomsHHR's Avatar
Search unemployed.....
There is 9 threads
Old Sep 10, 2007 | 10:15 PM
Paul EIler's Avatar
Drain plug in usual place. Under engine. Get a 32 MM socket to remove filter top. Be careful, there is not much room. Loosen top with socket and take off with fingers once loosened. No mess if engine is completely drained!!! Simple. Use 5W-30 Synthetic oil..Mobil one came in the car.
Old Sep 10, 2007 | 10:18 PM
Old Sep 10, 2007 | 10:25 PM
Black Rose's Avatar
Mobil Clean came in the car, not Mobil 1.
Only Corvettes and certain Cadillac's (CTS-V) get Mobil 1 from the factory.
Old Oct 29, 2009 | 08:33 PM
kreminm's Avatar
Where is the drain plug on an 07 HHR? Filter?
Old Oct 29, 2009 | 08:56 PM
Old Lar's Avatar
On the 2.4L engine the drain plug is on the oil pan while the filter is in a cartridge that is accessable from the top. I change my own oil as this HHR is the easist car to work on for oil changes. Mobil 1 from Walmart (5 qt jug $22 and filter fro Auto Zone $5) then less thae 1/2 hr of my time. ($89 at the dealer). I cheap and want to save $$.
Old Oct 29, 2009 | 09:15 PM
urbexHHR's Avatar
Good luck getting a pan under the car...I don't think you can barely get your arm under it...
Old Oct 30, 2009 | 07:29 AM
Old Lar's Avatar
I have no problem getting a pan or myself under the car. I have no need to jack up the car to get underneath and I'm a fat old man.
Old Oct 30, 2009 | 08:52 AM
urbexHHR's Avatar
Do you have hydraulic lifts or what???? I had to buy a new smaller oil pan because my normal one wouldn't fit.
