Oil fill cap
Old Sep 3, 2021 | 04:18 PM
haX0r's Avatar
Oil fill cap
Going on a maint binge. (will have a bunch of Q's coming up)
But one thing that has been pestering me for a while is the oil fill cap. It is a bugger to pull out. Turns just fine, just hard to pull out. O-ring just swelled? Tried a bit of grease, but a week later still stuck in there good. Gonna look for a silicone o-ring and try. I'm cheap, but also a tech and not just a parts changer (for the most part) Want to know *why* any part needs to be changed and what caused the failure.
TIA
Old Sep 3, 2021 | 05:04 PM
If your cap does not have "SAE 5-W30" printed on it it is not original. If you remove the tube the cap should fit in the hole on the valve cover.
Old Sep 3, 2021 | 05:06 PM
haX0r's Avatar
Its original. Bought the car new.
Might just pull the tube and polish it's inners.
Old Sep 3, 2021 | 05:20 PM
Both my oil fill caps never seized up or tightened up, I apply a few drops of fresh engine oil every oil change.
HipHotRod
2.4L Performance Tech
29
Sep 2, 2013 10:52 PM
8CH8CHR
Sep 14, 2010 12:15 PM
sleeper
Sep 7, 2010 01:43 AM
Lone Ranger
Sep 22, 2007 08:58 PM
Ern
Jun 19, 2007 04:50 PM
