Po301 misfire comes and goes
Old Jan 7, 2015 | 11:36 AM
Originally Posted by jdjaa1959
i was going to move the coil to another cylinder to see if the misfire follows but
logically for the $ 50.00 i should just replace it and rule that out. injector would be next,
not sure how hard of a job that is. Thank you
If you changed the plugs you had to remove the coils. If you have a 2006 the SINGLE coil is a lot more than $50.
Old Jan 7, 2015 | 12:33 PM
But Don, my friend read post#6 he has an '07
Old Jan 7, 2015 | 02:23 PM
Thus the "if".
Once more I am blaming the phone. It is difficult to go back while responding and my memory is not as good as I remember.
Old Jan 7, 2015 | 04:27 PM
Darn phones!!
Old Jan 7, 2015 | 08:09 PM
2oodoor's Avatar
My 07 2.4 doing the same thing, showed up about the same time colder weather did. It gets a little jerky for a second just about the same time one would expect the thermostat opening, once in a while. 301 code popped on last time it did that.
Im going to run a can of bg44k in the tank and see if that helps.
ULOS2A6
Mar 24, 2014 03:52 PM
JLD333
Jan 18, 2014 07:54 PM
Cheko0602
Dec 7, 2013 11:45 PM
dzmija
Oct 27, 2013 04:34 PM
tleffew66
Jun 11, 2013 11:16 PM
