Question on Coolant/Thermostat Replacement
Old 10-15-2013, 08:12 PM
10 gallons? No, just use it for the last flush - half of which will end up on the ground.
whopper is offline
Old 10-15-2013, 08:13 PM
Originally Posted by fastsuv
One last thing: Is the hose clamp on the thermostat housing reusable or should I buy a worm-gear clamp to replace it?
I know it should be reusable but has anyone had leaking problems after reusing it?
Steve
I reused mine with no problems. Just make sure to clean the thermostat housing where the hose attaches.
whopper is offline
Old 10-17-2013, 12:14 PM
fastsuv's Avatar
I checked our local NAPA auto parts stores and they show 2 Stant thermostats, an "OE Type" and an "OE Exact type". The difference is $27 vs $29.
Rock Auto also shows the two different Stant thermostats.
Anyone know what the difference is?
Steve
fastsuv is offline
Old 10-17-2013, 03:03 PM
Steve
$2.00
donbrew is offline
Old 10-17-2013, 03:55 PM
fastsuv's Avatar
Originally Posted by donbrew
$2.00
OK, I guess I should have been more specific about which difference I meant.
After reading more on the Stant site, the "OE-Exact" model is an exact copy of the original one. The "OE-Fit" model fits and works but doesn't look like the original.
Both would work, I don't know of any advantage to having it look exactly like the original. Advance Auto has a thermostat for $21 that I'll probably buy.
Steve
fastsuv is offline
Old 10-17-2013, 05:47 PM
Some of them do not have the center rubber gasket (the one that fails), I do not know which one that is. The one currently in my car does not have it, the 2 used ones in my toolbox do have it.
donbrew is offline
Old 10-21-2013, 03:48 PM
fastsuv's Avatar
Well, yesterday I replaced the thermostat and changed the coolant.
The drain plug was stuck. I had to make a tool out of polycarbonate to hold all 4 flaps on the drain plug so I could twist with more force without breaking it. Removing the two plastic panels underneath the right front corner of the car allowed easy access to the drain plug from underneath.
I had to flush 5 times with water (allowing the engine to reach operating temp each time) before the coolant was finally fairly clear.
The thermostat failure can be seen in the following pictures:
As you can see, the inside rubber seal was broken up and parts were hanging loose. This caused it to not close all the way.
Steve
fastsuv is offline
Old 10-21-2013, 08:15 PM
There is a tool made for the radiator drain, and new drainsC's are cheap. I got both from Advance mail order anyway, not sure about in-store.
donbrew is offline
Smoke Wagon
"How To" Tutorial Library
148
09-06-2016 11:29 AM
oldracer
Maintenance and Upkeep
07-04-2014 10:53 PM
Zagohhr
01-08-2012 04:44 PM
RICK167448
02-09-2011 08:28 AM
Quick Reply: Question on Coolant/Thermostat Replacement
