Should it stay or should it go?
Old Nov 28, 2023 | 04:56 PM
Jim_greav's Avatar
Hello all. I have a 2011 LT. It has about 150,000 miles on it, 75,000 of which are mine. The car has some transmission problems, overheats going up a steep hill, and intermittently has the gauges bobbing up and down. Realistically, am I going to get much more mileage out of it if I put money into fixing it?
Old Nov 28, 2023 | 06:11 PM
Most get more than 300,000 miles, if the owner cares enough to do regular maintenance.
Old Nov 28, 2023 | 09:05 PM
greg8453's Avatar
You have a lot more to go with a bit of work here and there.
Old Nov 29, 2023 | 07:28 AM
The gauges are most likely because the fuse box bolts need to be tightened. If the bolts feel "tight enough" give them some more.
Old Nov 29, 2023 | 08:39 AM
Lonwane's Avatar
I just crossed 210,000 and still going strong.
Old Nov 29, 2023 | 09:36 AM
I’m at 186,000 miles on my 2011, I put 400,000 on my 2007. So you’ll be wise to change the Dexcool, install a new AC Delco 131-158 thermostat, and change out the timing chain and balance shaft chain and water pump. A small investment for another 150,000 miles. Your transmission problems could be related to those fuse box bolts
katertot
Nov 3, 2023 08:34 AM
Big_ole_Dog
Feb 21, 2015 01:44 AM
pjmanue
Jan 13, 2015 11:42 PM
Buster Brown
Apr 30, 2012 05:55 AM
terryb44
Feb 24, 2012 10:36 AM
