starter clicks before engaging- 3 times-
Old May 8, 2015 | 09:05 AM
Silverfox's Avatar
Sounds like you found the problem.
I would go one step further and take that ground cable connection off and make sure it is a clean connection. Then put it back on and tighten it up.
If it is the one I think it is it probably has some rust or corrosion on the nut/washer. I replaced mine with a stainless washer and nylon lock nut so it won't corrode again nor come loose again.
It was Metric as I recall.
Good detective work...
Silverfox
Old May 8, 2015 | 09:08 AM
Chances are (Johnny Mathis reference) the ground strap was arcing. Better check for burned places.
Old May 8, 2015 | 02:44 PM
Then tie a yellow ribbon round that old Oak tree!!
Ok agreed no more Tony Orlando
Old May 9, 2015 | 06:05 AM
Rocket Dawg's Avatar
So far, so good...no clicks yesterday..
Old May 9, 2015 | 06:47 AM
Good to go!!
Old May 9, 2015 | 05:30 PM
Gee, oldblue, no Johnny Mathis comments?
Yesterday I was in a truck shop. I had delivered a rebuilt starter the day before. The rebuilt starter is sitting on the workbench next to a ground strap that is green in the braid and melted on the block end, and a brand new ground strap.
H'mmm, I wonder if they really needed that $600 starter.
Old May 9, 2015 | 06:58 PM
I just wear a funny grin!! I get misty!
Old May 19, 2015 | 09:12 AM
It's good to go, no more clicks. The loose ground near the battery was the problem.
How it got loose to begin with is another question as it has a lock nut on the bottom and had some resistance while i was tightening it. Weird.
nate71
Drivetrain (Excluding Engine)
15
Sep 11, 2019 07:48 AM
2005HHRauto
2.0L Performance Tech
Jul 3, 2016 10:44 AM
vanLienden
Jun 26, 2015 08:06 PM
emill713
Jun 20, 2013 10:27 AM
pea420
2.4L Performance Tech
11
Oct 16, 2007 09:36 PM
