Time for better brakes...
Well I've come to decide that the guy that I had do my brakes last time, did it on the cheap, and upcharged me. My dad could do this, but at the time, I didn't want anyone else driving myh car, but me. Greedy sounding I know. But it was still new to me then..
Now I'm getting squeaking from my pads, and I want to swap rotors to ones that don't warp easy. (Drilled?)
I want something along the lines of the rotors you see on performance cars. And pads to match.
Recommendations?
Thanks
Kevin
Recommendations?
Thanks
Kevin
I have drilled and slotted rotors from ebc brakes on my truck that I installed myself about 4 years ago. I have not had any problems with them and would recommend them to anyone. I had oreilly auto parts to order them for me.
I tried the napa heavy duty rotors and pads. They worked good for 2 weeks and then I had the same problem again just like the original rotors. Napa replaced them with 2 more new heavy duty rotors and pads and again I had the same problem so thats when I went to oreilly auto parts and one of the guys recommended the ebc brand drilled and slotted rotors. I haven't had any problems since then.
If you want looks the EBC drilled rotors are fine.
But if you want the best performaning rotors just save your money and get the solid Bendix. The drilled rotors are only cosmetic. The head of EBC taught me that. He said they only sell them for cosmetic reasons and they make a lot of money for them.
Save on the rotors and put the money were it will do the most good the pads. EBC reds are recomended for good performance and low dust. I also have used the Hawk pads and find them also very good.
The key to good brakes is heat transfer and the better pad material will do that more so than cheaper pads with lower quality materials. Ceramic and kevelar are the two best materials out now. Avoid anything with metal fillers. Also the solid rotors will absorb more heat than any drilled rotor.
The slotted will help clean the pad and do serve a function but most street driven cars really do not see the benefit since there is little loose rubber on the streets like on race tracks.
The cheaper pads like NAPA are fine for average driving but if you are hard on brakes I would only recomend the better pads.
Just make sure to seat them in as recomended. Fail to do this you will have issues later on. This is where so many people have issues as even mechanics today don't seat the pads as often as they should.
Note the EBC pads have a coating that help seat them in on them that wears off after a couple days.
What was once true for brakes in the past does not apply to todays brakes and materials are much better as are most of the systems out there today. Many cars have rotors today larger than wheels in the past. Things have really changed alot.
