transmission
Old Apr 21, 2013 | 01:34 PM
Ktmrider's Avatar
Does anyone know what the pan bolt torque specs are?
Old Apr 21, 2013 | 02:20 PM
db/sb's Avatar
The service manual says 106 in lbs for the pan to case bolts....yes that's in not ft which translates to just a shade under 9 ft lbs.
Old Apr 21, 2013 | 02:26 PM
Which is barely hand tight using a 1/4 inch drive. Do not snug them down, you will bend the sheet metal and cause a leak, done that!
Old Apr 21, 2013 | 02:54 PM
ronp's Avatar
hAd mine done at 75,000 AND 150,000
trany shop charged $70 for filter and fluid took about 30 min.
Old Apr 21, 2013 | 09:06 PM
db/sb's Avatar
I've always used a 1/4" drive spinner handle rather than a ratchet to tighten trans pans. I twist until the bolt contacts the pan and then about 1/4 turn more. Something like this one:
DANNY HUNTER
Maintenance and Upkeep
14
Jun 14, 2014 11:53 AM
dudeasif
Apr 5, 2012 11:04 AM
brett
Mar 30, 2009 11:31 AM
misterjensen
Mar 8, 2008 10:01 AM
