Wanting to change belt 2007 hhr
Old May 24, 2021 | 09:24 PM
hurst2001's Avatar
Got the 2.4 2007 with air and was in the boneyard to looking at one when and pulled the cover off .. I look at front of the compressor it look like just a round plastic cap .. so I know if has the triangle metal shape it would be a different belt .. any inputs
Old May 24, 2021 | 10:07 PM
So your's is different from the one in the boneyard ? So what. I hope you weren't looking for a used fan belt in a wrecking yard.
Do yourself a favor and get a new one. Not that expensive.
Old May 25, 2021 | 03:56 AM
hurst2001's Avatar
no I was just checking the same year 2007 2.4 before I get mine apart to make sure I get the right new belt ..
Old May 25, 2021 | 05:58 AM
Order the belt and tensioner as a kit.
Old May 25, 2021 | 08:19 AM
Lonwane's Avatar
From RockAuto and use our discount code
Old May 25, 2021 | 08:33 AM
Yes, they are different belts. I don't recall the specs.
Old May 25, 2021 | 08:40 AM
Won't matter what the junkyard HHR has because your's may be different.
The 2007 2.4 parts list shows 2 different belts, depending on which AC compressor your HHR has. You need to verify which compressor your car has before ordering the parts.
Old May 25, 2021 | 12:08 PM
I ordered the AC Delco kit, for the triangle compressor part,
Note in this screen shot , prices are listed in CDN funds.
Mmgsxr750
2.2L Performance Tech
18
May 24, 2015 09:38 PM
US66HHR
Apr 5, 2014 06:51 PM
Dwarf7az
Maintenance and Upkeep
Oct 11, 2013 11:04 AM
bigjacksauto
12
Jun 14, 2012 08:53 PM
RICK167448
Jul 26, 2010 08:42 AM
