Mods - Engine/Exhaust EngineCompartment/Exhaust Discussions. (Non-Performace)
best choice of engine swap for 2006 HHR
Old Jan 6, 2023 | 10:14 AM
Correct camshafts are different, so the sensors from the 2006 won’t see what the ECM is looking for.
the_shmoo’s 2006 2.4 doesn’t have the oil cooler as I recall.
Old Jan 6, 2023 | 10:30 AM
If the current engine has the oil cooler, and the replacement engine doesn't, you'd have to figure out what to do with the coolant hoses.
Old Jan 6, 2023 | 12:01 PM
Eliminate the smaller hoses and replace the larger hose with one without the tee and replace the thermostat housing with one from a 2007 model year
Old Jan 6, 2023 | 03:01 PM
arizonalone's Avatar
Thumbs up
You guys are great!
Old Jan 6, 2023 | 03:03 PM
Wish I could give you a hand swapping engines, a nice warm couple of days in Arizona, better then the 34 degrees here!
Old Jan 6, 2023 | 03:07 PM
Thank you old blue! Come on down, you would be very welcome!
Old Jan 6, 2023 | 03:51 PM
Coolant hoses are attached to the engine.
Old Jan 6, 2023 | 04:11 PM
Yes, and tee off to the oil cooler from the thermostat housing
This hose from the thermostat housing is eliminated, the housing is replaced with a 2007
This tee is eliminated and the rad hose from a 2007 is used to replace this mess
Old Jan 6, 2023 | 04:19 PM
This is the oil cooler style thermostat housing, this one I’d off my 2011 2.4 l , the black rubber cap can crack and leak coolant
This is the housing from a 2007 , note there is no provision for a heat hose to go to an oil cooler or get capped off and potentially leak coolant
Old Jan 6, 2023 | 06:55 PM
:) ! looks like the way to go yo me!
06 HHR LOVER
Nov 13, 2017 12:49 AM
Mom7082
Jan 11, 2017 10:34 AM
4404spd
Dec 2, 2015 11:48 AM
guppy
Mar 30, 2015 08:18 PM
