Best Paint for Grill Mod?
Old Jun 7, 2013 | 12:45 PM
BunglerHHr's Avatar
I need to do a Front Grill for my Panel, I had modded/painted a Chrome Grill but the paint has bubbled and peeled and looks like hell. I am going to mod/paint my original Silver painted Grill. Could anyone suggest a good and durable paint?
The color will be in Satin Black.
Thanks in advance
Old Jun 7, 2013 | 01:27 PM
walkowg's Avatar
you might try flat black paint dip also none as rubber dip. I did a jeep years ago and was happy also it will peal off if you change your mind later. Some one had a green hhr on here that they did the hole car this week. If you look on utube year will also find ways to do it
Old Jun 7, 2013 | 02:48 PM
Prep work is the key to a good paint job.
Sanding,cleaning and a good base or primer coat are needed before the application of the top coat.
Old Jun 7, 2013 | 06:15 PM
Good advise Fireman, I couldn't have said it better. I am thinking of spraying mine.
Boydie
Old Jun 7, 2013 | 08:12 PM
LawDog88's Avatar
You will want a high temp rattle can, unless you mean the grille on your HHR... in which case, you will want to do good prep work, and find a good plastic primer, and paint.
Old Jun 8, 2013 | 12:24 AM
Rustoleum paint sticks like glue, & gets hard as nails.. It ain't rocket science here.
eaglefreak138
Mods - Exterior
Aug 1, 2012 04:02 PM
foofoomaru
Mods - Exterior
Aug 14, 2011 05:35 PM
bowtieboy68
May 15, 2010 07:39 PM
lilchapo23jalexy
Mar 22, 2008 07:35 AM
SindyDix
Mods - Exterior
13
Apr 13, 2006 12:53 AM
