HHR mud gurard install?
Old Jul 31, 2007 | 04:47 AM
Originally Posted by dennisgu
Could anyone post some pics of the finished product?
With a little personal touch.........
Old Aug 7, 2007 | 12:59 AM
jp523's Avatar
Looks good!
Looks good, great even! Where are people getting these from? And what did you use to color the letters? Is that a decal or paint?
Thanks!
Old Jan 13, 2008 | 12:23 PM
jcgc50's Avatar
Removing the old snaps to install mudguards help
How in the world do you get the plastic plugs out. I have tried to pry them off and one had literally bent the underlying metal attachment slightly before I gave up for fear of damaging the fender.
Old Jan 13, 2008 | 12:43 PM
bigallis1's Avatar
Welcome to the site.
Yes, they can be difficult. I happened to have a a tool for popping inner car door panels off. It's no more than a flat piece of 1/8th" steel plate with a narrow slot in it that slides under the head of the fastener and pops it out.
If you can work the head of the fastener out enough to get a thin pair of wire cutters under it, just cut the fastener and you will be all set.
Good luck................
Old Jan 13, 2008 | 12:46 PM
Memphis_HHR's Avatar
Door Panel tool available at AutoZone. I bought this a long time ago and it has become quite handy.
Old Jan 13, 2008 | 01:40 PM
Black Rose's Avatar
I cut mine off with a pair of pliers that had wire cutters built in.
Old Jan 13, 2008 | 02:57 PM
jcgc50's Avatar
Thanks folks, I cut them off with wire cutters. I have the trim panel tool you are talking about but when I tried that it actually bent the thin metal tab on the front fender.
The tab is just not strong enough to resist the pull. Would be nice if the instructions were more explicit about that.
Jim
Old Jan 13, 2008 | 03:03 PM
You could have wiggled them back and forth and popped them out a ridge at a time and the metal tab would have been fine. It's one of those "take your time" things and do it right. Bottom line is you got it done.
Old Jan 13, 2008 | 08:02 PM
Smoke Wagon's Avatar
while taking a very close look at my car today on the rack, I did notice that there is a provision hole in the bottom part of the mud flap where it molds to the inner fenders...but there is no hole in the body work to use that as a mounting location.
The rear ones particularly...on the inside of them, where they would mount to the bottom edge of the bumper cover(which is half of your wheel well), the mud flap has a hole...the bumper does not.
I could see no harm in drilling a hole and installing a clip or screw/speed-nut...but after closer inspection, I didnt see it as being necessary. They seem sturdy without that last hole being clipped/screwed on.
Old Jan 18, 2008 | 05:32 PM
bigallis1's Avatar
Installation instructions I got with mine, said to drill a hole on the bottom of the fender where the hole in the flap is. Install screw provided.
