HHR SS Front Grille
Old 04-13-2008, 01:49 PM
goatcheez's Avatar
HHR SS Front Grille
Anyone have a HHR parts connection?? I'm looking for an SS grille (red & black) for my LS. Just grille only. It would fit nicely with the look I'm going for with my HHR. Thanks for your help!
goatcheez
goatcheez is offline
Old 04-13-2008, 02:49 PM
1Panel2NV's Avatar
I don't think it will work with non SS's, unless you get the bumper as well.
1Panel2NV is offline
Old 04-13-2008, 02:52 PM
Yup, ain't gonna work unless you go all out. The SS grille is larger.
GDZHHR is offline
Old 04-13-2008, 04:24 PM
GTOMIKE's Avatar
The part # is 25918728 not going to fit unless you shorten it you can always make one out of your stock one like I did.
GTOMIKE is offline
Old 04-13-2008, 05:32 PM
goatcheez's Avatar
Thanks for the info guys!! At first glance it looks like it'll fit. But yep, you're right not gonna happen. How did you make yours?? Was it difficult?? Did you have a bodyshop paint it?? That's exactly the look I want!
goatcheez
Old 04-13-2008, 06:13 PM
GTOMIKE's Avatar
goatcheez
All the info is here in this link, paint was from a spray can perfect match https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/one-bar-wonder-grill-done-13829/
GTOMIKE is offline
Old 04-13-2008, 09:23 PM
The Curly 1's Avatar
I was told it does fit.
I was told it does fit and ordered one from Chevy. I has came in and been painted and they are going to install it Tuesday.
I guess I will know then.......
The Curly 1 is offline
Old 04-13-2008, 09:26 PM
xzombiex66's Avatar
The SS bumper is actually notched out for the Grille, the standard HHR bumper is not,good luck. There is a pic floating around here somewhere showing that it will not fit correctly.
xzombiex66 is offline
Old 04-13-2008, 09:36 PM
xzombiex66's Avatar
Check out the pic in this thread and you will see what i mean.
https://www.chevyhhr.net/forums/hhr-ss-45/front-grille-emblem-12302/
Old 04-13-2008, 09:38 PM
Snoopy's Avatar
It WILL FIT.....if you do a little modding.
As stated the SS bumper is relieved for the extra inch or so, of the SS grill height. But the only thing preventing the SS grill from fitting is some impact foam behind the plastic bumper cover. Once the foam is relieved the bumper cover is flexible enough to allow the grill to fit. If you spend time and do it right, it would look great.
I know cause, I did done seed it already. And might have mine done....but I want it in chrome...real black chrome.
Snoopy is offline
Quick Reply: HHR SS Front Grille
