Hid and drl relay
Old Feb 24, 2016 | 06:25 PM
Xlh883's Avatar
Originally Posted by donbrew
If you keep scrolling you will see that there is a divider "related threads". Everything below that is "similar threads".
What flickering? If you pull the fuse and the relay. or just the fuse.
From not using the harness. Like as if it wouldn't get enough voltage from the headlight wires vs the relay harness that is connected to the fuse panel
Old Feb 24, 2016 | 06:49 PM
I am confused. What's wrong with headlights if you disable DRL? They are separate.
Old Feb 24, 2016 | 07:02 PM
Xlh883's Avatar
When you add the hids. Instead of adding the harness with the relay you pull the drl fuse and just hook them up like a regular hid kit. Cars plug to ballast, ballast to bulb. Using the plugs from the headlight on both sides
Old Feb 24, 2016 | 07:41 PM
When the DRL is on the low beams are off. When the headlights are on the DRL is off.
Your problem is going to be managing hi-beams.
Old Feb 24, 2016 | 07:57 PM
Xlh883's Avatar
The drl is a lower voltage through the bulb right? Whether high or low doesn't really matter because once I pull the fuse it will be inop. Then since they are disabled I won't need the harness kit to hook up the hids the high low function will still function
Old Feb 25, 2016 | 07:37 AM
But HIDS don't normally have hi & low (thanks gods).
Please read the instruction and re aim the headlights properly, don't be an a-hole blinding us old folk.
Old Feb 25, 2016 | 08:37 AM
solman98's Avatar
I had the hi/low function with my HIDs. And yes I aimed them down.
I wish I had put the tripod higher, I set it at headlight level. But you can see the hi/low function works.
Lightscameraaction.mp4 Video by solman98 | Photobucket
Old Feb 25, 2016 | 02:02 PM
Putter's Avatar
UNLESS.....you do a retro-fit with projectors. I have normal high/low beam function using projectors and HIDs inside a set of Depos using a wiring harness from The Retrofit Source (less than $30). I pulled the fuse for my DRLs under the hood and have zero issues.
Old Feb 25, 2016 | 05:45 PM
skyline26's Avatar
^^ those lights look good man! did you do them yourself?
Old Mar 3, 2016 | 07:27 PM
Xlh883's Avatar
I installed them with the relay harness (it's such a mission to put the bulbs and ballasts in the harness was the easy part) and just pulled the drl relay and everything works great. Took about an hour
Shanes0406
7
Jul 26, 2012 03:12 PM
2smokey
28
Nov 5, 2010 11:48 AM
Melodale
Sep 13, 2009 06:14 PM
impulse91
Jul 16, 2009 08:57 PM
tcstoy
Jul 10, 2008 10:12 AM
