LED Bulb Replacement - Load Equalizer Questions
Old 06-13-2017, 11:59 PM
  #31
Lonwane's Avatar
So to further clarify....Does the Cruise Control not disengage when the brakes are used? That would seem to be the issue as that is the only time those lights are used. I will admit that I am just guessing.
Thanx again for ALL of your help.
Lonwane is offline
Old 06-14-2017, 08:13 AM
  #32
When the third light illuminates the CC turns off. The CC will not turn on if the third brake light didn't work when you put it into gear. On a standard trans car you need to use the brake sometime before you turn the CC on.
Computers!
donbrew is offline
Old 06-14-2017, 08:30 AM
  #33
Lonwane's Avatar
O K Thanx. By the way, who's idea was this? I thought engineers were supposed to be smart. Or are they smarter than they let on? A conspiracy? HMMMMM!
Lonwane is offline
Old 10-23-2017, 11:27 AM
  #34
lilricky's Avatar
If they were smart, they wouldn't have designed the HHR so you have to remove shrouds and do a blind feel, just to change the head lamps!
lilricky is offline
cannuck
03-03-2010 01:05 AM
gcsd3742
04-03-2009 08:29 PM
405HP_Z06
2.0L Performance Tech
10-07-2008 08:17 AM
geodesic
10-16-2007 11:12 AM
BelizeBrian
12-19-2006 02:46 PM
Quick Reply: LED Bulb Replacement - Load Equalizer Questions
