My $1.08 Lower Grille Mod on Shaggy and Shaggy Has New Teeth
Old Aug 12, 2006 | 11:28 AM
  #71
cj krause's Avatar
Originally Posted by bgnoz
hey cj...your first post said you flattend the mesh? did you just mash it with a hammer on the concrete? from your pics i cant tell that you have even smashed it, i'm on my way to lowes this morning and will be putting this great piece of insurance on... thank you all... i love the site!
the bgnozdude
when you flatten the mesh by bending the outside curves to make it flat, the mesh bown. i just put my ringers on opposite edges and thumbs in the middle and pulled it straight
i then moved the clips to the opposite of where they were, 9 inches in and hooked them in the 3rd holes down to make the top line up
after i had it in place and flat against the opening in the grille, i laid my hands flat against the mesh and gently used my fingers to bend the end of the mesh over the bottom of the opening to make it lay flat against it. took some dikes and cut lil lines where the bolts and corners were so the sides laid flat around the opening as well.
this way it looks custom fit
Old Aug 12, 2006 | 12:23 PM
  #72
robado's Avatar
Hey cj thanks for the mod idea I found mine at Menards. And the whole process only took about 30 min.
Just wondering what everyone thinks of the pic. I am not sure if I am going to leave it this way or not. I am open to suggestions. I just painted the whole thing black except for the HHR part. Still more touch up but you get the idea.
Old Aug 12, 2006 | 12:32 PM
  #73
El_Guapo's Avatar
Originally Posted by robado
Hey cj thanks for the mod idea I found mine at Menards. And the whole process only took about 10 min.
that looks cool... I like it...
Old Aug 12, 2006 | 12:38 PM
  #74
cj krause's Avatar
looks great, prob is that area is really hard to see so not many will see it
if the grille was in the front of the opening it would be seen alot more
Old Aug 12, 2006 | 03:25 PM
  #75
nfboy's Avatar
Good question and I was not clear on this.
CJ if I am reading your reply correctly you actually did not flatten the mesh itself, but just bent it so the curvature for its intended rain gutter purpose was removed? That was what I thought you had done, not made the hole mesh thing flat by pounding the poo out of it.
Old Aug 12, 2006 | 03:30 PM
  #76
cj krause's Avatar
i dont like to pound poo,,,, that stuff is stinky and goes everywhere.
Old Aug 12, 2006 | 09:10 PM
  #77
bgnoz's Avatar
thank you CJ and everyone else for this mod... i went with a smaller mesh that you buy on a roll, i now have 20 feet left, so i have many lower grills that i can make...
this took me and my buddy just under a hour to do... not sure if i clipped it right but it is on there tight..
the bgnozdude
Old Aug 12, 2006 | 09:51 PM
  #78
cj krause's Avatar
looks real good
that is all that matters
Old Aug 12, 2006 | 09:59 PM
  #79
JimZ_HHR's Avatar
is it me? or is the bottom lip pullled up?
Old Aug 12, 2006 | 11:38 PM
  #80
cj krause's Avatar
he does have 3 clips attached to the bottom holding the mesh there i assume
that might raise it
here is a pic of mine. i only put clips on the top and wrapped it around the bottom.
