Painting OEM Hubcaps
Old Mar 1, 2012 | 07:52 PM
LeadReign's Avatar
Has anyone ever painted their hubcaps? I sure could use some input on this. If there is a thread sorry for this post please point me in right direction. Very wary of doing this mod. Not really good with paint. I have a blackout theme going with my car i took the hubcaps to see the metal 5 star wheels underneath. I like the black look just not how raw my wheels look without hubcaps on.
Old Mar 1, 2012 | 08:17 PM
badassbowtie's Avatar
If you can handle using spray paint its relatively easy. the way i did it a few years ago with my cobalt is simple and lasted until i traded it in. i would clean them good 1st. after a good wash, i would use parts cleaner or something to that effect to remove any tire shine oils or road grime. then use a scotch brite pad to scuff up the surface so the paint will stick. i used like four coats of flat black spray paint on mine and then two coats of clear coat. i waited about 20 minutes between coats. then let them dry for a day or so and you should be good to go. have some paint thinner around too, incase you start and dont like what youve done. then you can clean them off and start over. Good Luck
Old Mar 1, 2012 | 08:23 PM
gguy1's Avatar
Home centers do make special spray pain for plastics, I have had good luck on other things, always remember, a few thin coats rather than one thick coat, and rotate to find missed spots!!
Old Mar 2, 2012 | 02:21 PM
have you concidered painting the black five spoke rims the colour you want to see how this looks and then the hub caps if you want , my steel rims were chipped and rusty so I painted them and stopped ther as I liked this look, just a thought!
Old Mar 5, 2012 | 05:07 PM
GR$$N$'s Avatar
go to a home depot if you have one near you.or any home center. they have this spray can its called "plasti dip" all you have to do is use wheel cleaner on the caps,hose them off.let them dry and spray it on. now onto the good part of the plasti dip.if you dont like it, you can peel it right off. also you can get an ahesion promotor to make it more gloss since just the plasti dip can will make it a flat black.
if you dont want that.clean them.scuff them up with some fine sand paper.reclean them(make sure you're wearing clean gloves this whole time) get some plastic primer and spray a 2-3 coats of that. once that is fully dry. either take some rustoleum paint or some plastic paint and spray a few coats on there.now i dont do clear coats when i just rattle can paint.i dont have chipping problems.but some people like to clear them as well it just seems to get more orange peel when you clear them.
Old May 21, 2012 | 02:56 PM
justaddmayo's Avatar
I'm wanting to do this to my steel rims. They are showing rust. What would I use to paint the rims? Thanks very much.
Old May 21, 2012 | 03:15 PM
to the forum justaddmayo!
If you're wanting to repaint your stock steel rims black like they were when new, head to your auto parts store or hardware store and get some gloss or semi gloss black wheel paint in a spray can.
Clean your rims thoroughly and lightly sand any rusty areas, then mask off the tires. Follow the directions on the paint, give 'em at least two good coats, then stand back to admire your work.
Take your time and its a piece of cake.
Old May 21, 2012 | 07:02 PM
bowtieboy68's Avatar
i taped my hubcaps off, then scuffed them, then used black krylon and cleared them.
they last pretty well over the harsh N.I. winters too!
Old May 22, 2012 | 02:21 PM
Thank you
Thanks for the welcome and the info 843de. I appreciate it.
plakman
Jul 25, 2007 06:19 PM
plakman
14
Jul 20, 2007 08:52 PM
plakman
Jun 27, 2007 02:52 PM
KY Dave
17
Mar 24, 2006 02:16 PM
