Side Adhesives in front of rear wheel wells
I don't even know what to call these other than stickers, but what are the adhesive panels (stickers) on the side of the HHR in front of the rear wheel wells? Mine are dinged up pretty good and on a black car it really stands out. Can these be replaced, removed, etc, is there regular body paint under those adhesives?
Film, Protective Covering L/H PN# 25791042
Film, Protective Covering R/H PN# 25791044
GM list price on each is $35.21
These folks have it....or did the last time I checked.
http://www.gmpartsgiant.com/parts/gm-film-25791042.html
http://www.gmpartsgiant.com/parts/gm-film-25791044.html
http://www.gmpartsdirect.com/
I had mine replaced under warranty, must be a PITA. Left car all day and went to pick up they only had one side done. They apologized with a free oil change, said they were going to send to collision shop to do other side. The side they did do I could see the old adhesive behind clear film, so that had to be done over again. It is body paint behind them. I had added boards and was tempted to leave them off but went for the extra protection. If applied properly and maintained they're hardly noticeable.
[QUOTE=843de;648584]Film, Protective Covering L/H PN# 25791042
Are the two part numbers above the verticle piece only for the rear door or would that also include the smaller horizontal piece located on the plastic rocker panel?
Recently ordered a 12" X 72" piece of the 3M 8mil/.20mm clear stone/chip guard from Amazon @ aprox $9.50 sq ft. This stuff is a PITA to cut (all the further I've got on this project) due to it's excessively elastic quality when compared to vinyl. My understanding is it requires hard squeeging to apply without bubbles and the crux of that is it will also distort or stretch if improperly squeeged. It can be controled during application with moderate heat.
In hindsight, I should have explored a paintable rubberized product prior to having this area repainted.
