Did you mask off the Ecotec or remove the paint after it dried and before the clear coat?
Again
I used a 3M 2" pad on my angle air grinder to take the paint off after the 1st coat set up, then masked it off to put on a couple of more coats.Then cleared it.
any chance you save part numbers for that intake? and did it throw any codes?
Sorry,don't have any part numbers.Should be able to pick up parts from your local parts house.Have had this set up for around 7-8 months and not the 1st code
