Adding a voltmeter
I did some looking back over the years and came up dry, so you may be a pioneer here.
Once you've decided on the gauge you want(Autometer products, and Stewart-Warner products have always been my preferred choices), the installation instructions should give you an approximate idea of where to tap for the hot side and ground.
You might even want to contact a gauge manufacturer to see if their tech people have experience with HHR installations.
As far as a mounting location, the A-Pillars seem to be the favorite spot for any additional gauges.
The SS's with the RPD unit have a built in voltage meter. A neat place to put an add on meter would be an A pillar mount. The non RPD SS's have the boost guage mounted in the A pillar. Maybe you could get a SS pillar cover and try that.
Attachment 15464
Attachment 15464
That ones waaay out of my league Mike.
Seriously though. Probably too much of a hassle. The RPD is tied in with the SS's ECM, BCM and who knows where else. The g force meter, boost meter and other readings would be unique to the SS programming and electronics.
Did I mention, waaaaay out of my league? I wouldn't even know where to start to try and put one in a non SS.
I do recall someone posting up that if you remove the RPD, the SS will not even run. Scary thought about trying to mess with one.
I installed a volt meter in my 08 panel. I used a gauge pillar out of an SS. I removed the boost gauge and installed a volt gauge. It makes a nice clean set up however the a piller for the SS comes with the boost gauge and the twiter speaker so its expensive. I think they were getting about 250.00 for it from the dealer. if you want to go that route start calling around to the bone yards and look at ebay they show up there now and then. as far as nooking up the volt meter any swich power will do. I just taped on to the fuse box.
I can either glass one in somewhere or cut one into an existing panel, haven't figured that out yet.
I have Cyberdyne in my show truck, just looking for ideas.
And yes, like all great forum members should, I searched first! WOOT!
OBDII reports ECM voltage, or from the pos pin on the OBDII connector.
I was thumbing that on my stupid phone.
What I was meaning is: a scanner can report the voltage that the ECM is receiving. Or, alternatively the positive pin on the OBDII port has battery voltage.
If anybody cares I think I could find the PID. Let me know.
