Mods - Interior Discussion related to the looks of the interior of the HHR.
Woodgrain dash kit install
Old Mar 28, 2013 | 04:54 PM
hhrumadbruh's Avatar
Am I the only one who can't view the pictures? They are like avatar size. Very small
Old Mar 28, 2013 | 05:00 PM
NYCHHR's Avatar
Just click the camera icon on the first posting profile to go to the gallery. You can see them there.
Old Apr 4, 2013 | 10:39 PM
tucsondivots's Avatar
The piece that goes on the right side of the steering wheel (curved) does not stick well. Any suggestions on some kind of glue and process to fix it? Other side sticks fine, but buying a single piece from acrid is expensive.
Old Apr 4, 2013 | 11:52 PM
F-16C's Avatar
I had a piece that did the same thing { It was the rear door window switch trim}. I called Sherwood directly and they found my order and sent me a new piece. If and when you get the piece you need, wipe the area down with grease and wax remover. I did this on the steering wheel and glove box area due to I knew it had oil from my hands on those areas. also the adhesion promoter pads worked good and I have had no problems.
Old Apr 6, 2013 | 06:56 PM
Thanks. My issue is the piece is over a year old. I am hoping to somehow glue it down. The part that comes up is on the lower side of the curve on the steering wheel, so it does not look bad.
oldracer
Mods - Interior
18
Jun 20, 2013 12:09 PM
Laez
Apr 28, 2013 01:07 PM
joekat
Mods - Interior
Jun 2, 2012 12:28 PM
Violet_HHR
10
Nov 28, 2007 12:33 PM
