06 HHR LT 2.4 Engine power reduced engine no crank Fathers Day Fiasco
Old Aug 18, 2024 | 06:00 PM
BrindleBully's Avatar
Yes according to the government website for recalls there are 0 unrepaired recalls for our HHR LT. So the ignition recalls have been taken care of.
Old Aug 18, 2024 | 06:01 PM
And as for the Run/Crank relay, it has been replaced also.
Old Aug 21, 2024 | 08:21 AM
Got it fixed.
Well thank you to those that tried to help with my father's day troubles on my 06 HHR LT 2.4. Unfortunately what ideas were given didn't really help much. But what did the trick was just a bit of patience and pulling all the relays and fuses then reinstall them then clear the codes and repeat that process about fifteen times . Then it just started right up with no codes, no reduced engine power, no messages about the power steering, no check engine light. Nothing and for a while the car had 1 head light that would only shine at half power. But couldn't figure out why. It seems to have some how repaired that as well. I had changed the bulbs, I replaced the socket 2 times and it just kept burning at half power. But now it's working fine. Everything seems to be working better than it had in a long time. I think now might be when we say enough with this damn nightmare and get rid of this damn disappointment of a failure in Chevrolet design department and get a new car. This thing has been a plague since my old lady got it. The front end components have had to be changed every year, the electrical system has had me worried about when is the car b que going to happen on the highway several times. The door handles have broken off of each door inside and outside more times then I care to count. These things are the reason I will never own another Chevrolet again. Good luck to the rest of you. You are going to need it.
Old Aug 21, 2024 | 09:24 AM
Ok, happy trails! I didn’t see your response to post #2 and #3 you state you know about it but don’t confirm you tightened those bolts.
But moot point , by the way the wire harness and fuse box were developed by Saab
Old Aug 21, 2024 | 03:12 PM
PulpFriction's Avatar
Glad it worked out! When I first read your post, I thought you were going to ask for help getting rid of the kittens. That would have been much more challenging.
angelahamby
Nov 25, 2023 05:44 PM
catsarenttacos
Sep 23, 2023 07:31 AM
KenK
Mar 13, 2022 08:10 PM
LarryLarry
Jan 25, 2021 05:48 PM
sgmartin6
Jul 22, 2013 08:07 PM
