2007 chevy hhr ..crate motor replacment and seizure
Old Nov 25, 2023 | 03:25 PM
angelahamby's Avatar
We just acquired this vehicle for our son and have replaced just about everything known to man on it as well as a new crate motor ...made sure to get all the fluids correct lube everything and she starts for about 5 mins then dies and now is acting as tho she's locked up ...there was plenty of coolant ,oil ,ect not sure why any ideas....just to make sure it's known we had the starter tested and it's fine so is the battery .. all it does is click loudly now but it did run and also we tried to hand turn the crank it will not move ....just bouncing ideas plz any help appreciated truly p s. It never got hot either
Old Nov 25, 2023 | 03:51 PM
Welcome to the site, click? Like an electrical click? Tighten the under hood fuse box bolts , past the clicks until they are tight. Push all the fuses and relays into position firmly. Check your work, inspect all wire connections and ground wires make sure none were missed during reassembly.
check for fuel pressure, 55 to 60 psi and it should hold pressure awhile after you turn off the ignition switch.
just to confirm, which engine 2.2 or 2.4? Is it an automatic or manual transmission?
Old Nov 25, 2023 | 03:57 PM
It's a 2.2....it was running for 10 mis...then just shut off. The starter just clicked...took starter to be checked and its in good working order, lit back on the car....click click...looked at crank as being started....moved 1/8" at a time.. then nothing
Old Nov 25, 2023 | 04:44 PM
Checked the battery and connections?
What does "acting as tho she's locked up" mean to you?
Tried turning the belt by hand?
Contacted whoever installed it? Contacted whoever sold it?
Clicking from where? The solenoid, the starter motor, the relay.
Voltage at the starter, the fuse box, the alternator and the battery should be 12.5 or more.
The most frequent problem after a motor swap is the fuse box is not tightened down enough. People are afraid the bolts will strip. Second is the wires on the fuse box get put on wrong; there should be 2 on the front terminal (from battery/to starter) a only 1 (to power steering) closest to the firewall.
Did the starter get reinstalled squarely?
Can you measure the amp draw of the starter? What does "in good working order" mean to you? Was it tested on a machine by a professional or just bench tested with voltage?
Old Nov 25, 2023 | 04:58 PM
greg8453's Avatar
You can't turn the crank without plugs? If so, you will need to tear that engine down.
Old Nov 25, 2023 | 05:44 PM
Is this an automatic or manual transmission?
oheighthhr
Oct 30, 2023 05:27 PM
catsarenttacos
Sep 23, 2023 07:31 AM
hillbilly4u
Oct 25, 2021 03:46 PM
1bad89irocz
Aug 18, 2014 09:05 PM
delta88
Jun 19, 2012 06:20 PM
