06 hhr temp not reading but a/c works
Old 08-22-2018, 11:29 AM
Jaredshorty's Avatar
So a week ago I ran into the problem of my temperature gauge reading zero and - - - F when I look at the coolant temperature on the dash board and my a/c was blowing out hot air instead of cold. I did research and ended up replacing the thermostat a week ago, just today I got into my car to goto work and the temp gauge wasn’t reading again but this time my air conditioner was blowing cool air. Help! Could it be the sensor ? I have a Chevy hhr 2006
Jaredshorty is offline
Old 08-22-2018, 11:47 AM
Sensor or you disturbed the wires.
donbrew is offline
Old 08-22-2018, 02:06 PM
Did you attempt a download of the error codes from the Check engine Light, even if it didn't light the CEL for you?
whopper is offline
Old 08-22-2018, 08:42 PM
Welcome to the site, I’m thinking code P0128, used the wrong thermostat.
it just has to be an AC Delco 131-158 180 degree thermostat and 50/50 Dexcool and distilled water.
Oldblue is offline
Old 03-15-2019, 05:32 PM
mika_navajas's Avatar
Same issue but gauge resets when I disconnect my battery
I am having the same issue but I am able to reset the gauge by disconnecting my battery and reconnecting... However, 15 minutes into driving it will stop working again. Also, even with resetting, the temperature read on the dash never gets a read and stays showing ——F. Is this also a sensor issue?
mika_navajas is offline
Old 03-15-2019, 06:10 PM
Welcome to the site, Mika! Do you have that code? Have you replaced the thermostat?
Changed the Dexcool?
Oldblue is offline
Old 03-15-2019, 08:13 PM
I bet 25 cents it is P0128. You need a new ACDelco 131-158 t-stat.
donbrew is offline
Old 03-17-2019, 03:24 PM
codes
I got a p0010 camshaft position actuator circuit code and p0128 thermostat below regulating temp code.
I changed the intake and exhaust VVT solenoids. But still need to drive it to see if that did anything to solve my problem. I’ll let you know.
Old 03-17-2019, 03:31 PM
The p0128 is TOTALLY independent on the p0010 code.
whopper is offline
Old 03-17-2019, 05:57 PM
X2, get an AC Delco 131-158 thermostat and fresh Dexcool 50/50 coolant.
Oldblue is offline
Quick Reply: 06 hhr temp not reading but a/c works
