'08 HHR LT no crank no start, fuel pump powers on
Tomorrow I will start looking at the clutch pedal assembly to see if there is something that could possibly cause the ECM to not recognize pedal input (loose connections etc.).
This is one of the rare instances I hope the car would actually have some fault code.
Atleast then I would have a clue on why it's unhappy.
I changed the ignition switch because that recall was not done on this car, and that caused the starter solenoid to start doing one short click, but in the ''wrong spot''. The starter solenoid clicks when I turn the key to the RUN position, and when I turn the key to the START position absolutely nothing happens and the solenoid clicks again when I turn the key to the ACC position. This to me just sounds like either the replacement ignition switch is faulty, I somehow managed to install it the wrong way or there is something even more wrong with the car.
I've charged batteries and had them drop to 10.5V in 15 minutes. To be more specific, I'd like to know what the voltage is on a cold morning after a charge the day before. And again, the age of the battery. Low voltage can make some systems work but fail to trip an apparently good solenoid. Hotwiring to bypass the starter solenoid can continue to mask a bad battery. But there is no information here that shows a bad battery has been eliminated.
Hello again! After taking a break from the car for a few months (mainly due to it being cold outside), I decided to try again.
What I did was change the original ignition switch bits back to see if that would change anything (it did not). I also tried to see if there was any obvious issues with the clutch position sensor wiring, couldn't find anything.
And just to refresh my memory I checked through the fuses and relays again (also tightened the 7mm bolts once again just to be safe) and I couldn't find any non-functioning ones.
I also tried starting it with a brand new battery from my other daily driver, but that didn't change anything, it still wont crank over.
I'm running out of ideas. My guess is that either the clutch position sensor itself has conked out, some grounding point that I don't know of is corroded or one of the control modules is malfunctioning.
musicman190
Feb 25, 2014 02:53 PM
