2006 HHR Blower Motor AGAIN!
Old May 2, 2011 | 08:42 AM
jacob67's Avatar
bcm3 fuse
wish i had done a little bit more research before i removed the blower motor
had the same symptems as many others, but finally found a thread that talked about replacing the bcm3 fuse (still not sure what that is, B__ competer module?)
although the guy that suggested heating up the utility knife before cutting, thanks that worked perfectly and made a very clean cut
now on my way to the dealer to see if they have a repair kit for the blower motor box
Old May 2, 2011 | 09:48 AM
Body Control Module
Old Jan 1, 2016 | 07:02 PM
Jam815's Avatar
OK, how do you remove blower motor connector???
Is there a trick to it?
The blue piece moves but does not seem to make any difference.
Thanks, Jim
Old Jan 2, 2016 | 09:09 AM
Remove the lock clip, press the tang to release the lock , pull out connector.
Element
Sep 20, 2013 02:45 PM
kniffen
Mar 6, 2013 08:13 PM
kuzzins
Aug 7, 2011 03:16 PM
