2006 HHR Died on interstate Stuck in gear oil in engine
My guess is a transmission cooling line going to the radiator/trans cooler ruptured. This would account for both the oil all over and the high revving with no forward progress. If things weren't overheated too badly it may only require a repair of the line and refilling the trans. If it was run for any length of time with low fluid the outcome may be more grim.
The color of fluid is not always apparent unless it is against a light colored surface. And it may not be all that red if it hasn't been changed recently...
Overreved the engine and now it won't even turn over.= Does not look good.
Blew fluids all over the engine.= Does not look good at all.
Sorry, but it looks like it could be terminal. First thing I would check for is to see if the engine seized up. Hopefully not.
Over-revving is a possibility, but the rev limiter on the 2.2/2.4 "is supposed to" cut in at 6,600 rpm. I believe that if the transmission is overheated beyond a certain point, the ECM will prevent re-starting the engine, but I have to check the manuals in the morning.
& the fan is electric, & if engine is hot, it can run for a while after engine is off...
Ok so my dad said the shop put a breaker bar on the engine and couldn't get it to turn over. They drained the oil and said it had around 5qts in it. They think it could possibly be an engine bearing but that still doesn't explain the fluid all over the lower engine compartment. I still think its the transmission. So I told my dad to have them put a computer on it and see if they could pull any codes. I'm wondering if its this rev-limiter. I will let you know what I find out.
That was my question as well.
It doesn't take a lot of oil to coat everything in a situation like this. Half a qt can make a huge mess in an enging bay. But I'm still wondering why the tranny would shift or accelerate. Might be combination of oil and hyd fluid.
If the shop put a breaker bar on the engine and couldn't get it to turn over, then you're looking at serious internal damage. In other words, it sounds like it "seized up". Time for a rebuild at minimum or a new/used engine.
And worse yet, you could also be looking at a bad transmission too. Sorry, but based on what you've stated so far, it sounds like the transmission died and took the engine with it. Unfortunate, but very possible
Still no word from the shop so I assume the engine is dead and gone
Well if it weren't for bad luck I'd have no luck at all I guess.
I've started a search for a good used engine and tranny. I think I sourced an engine with 23,000 on it for $1000 delivered Which I think is a steal. However I am still looking for a transmission. I am not really looking to spend more than $1500 on it because I would hate for him to put the same amount of money he paid for the car into a new motor and transmission.
Thank you all for all your help!
" Put a computer on it and see if they could pull any codes" is going to be a waste of time.
