2006 HHR Door locks- All dead-dealer no help
Old Feb 16, 2024 | 10:51 PM
foghorns's Avatar
Just a follow up on my door lock problem. The dealer is saying that the BCM is good and all wires are good. Thus, all four of my door lock actuators are bad. I'm saying B.S. They were working when I took to them to change the BCM and I can't see all failing at the same time. They said it could have been a power surge, yea wright. if it did, they caused it. in order to verify this, is there a way to run direct power to a door actuator., to test it. please let me know. Thanks again for the help.
p.s. I can't wait to write a review about this rip off.
Old Feb 17, 2024 | 07:57 AM
I posted a wiring diagram on page #1. That would show how to hot wire.
Old Feb 17, 2024 | 10:49 AM
Double check the ground wire locations
Old Feb 18, 2024 | 11:50 AM
PulpFriction's Avatar
I look at the wiring diagram and see that the relays have common power and ground. So damage to either or a bad connector or ground would explain all door locks leaving the chat together. Maybe they screwed up a wire or connector when they put in the new BCM.
So yeah, jumpering the power and ground should narrow things down.
Maybe I buried my questions, or they were already answered (sorry) maybe you though they were irrelevant; Do you hear any noise at all (either up or down?) Did any of them ever operate part way? Can you operate the locks with the manual buttons? Do they seem stiff?
I agree, a dealer not taking responsibility for the what they obviously messed up is shocking typical.
Old Feb 18, 2024 | 12:43 PM
Hard to imagine all 4 actuators went bad at the same time, while at the shop.hard to imagine more than 1 ground going bad. A common point is "logic" on the left side of the diagram that donbrew shared. Looks like it's part of the BCM?
Have you checked that the fuse is getting power?
Old Feb 18, 2024 | 12:51 PM
Door lock fuse, 15 amp as mentioned, and ground behind left side of dash are both common to all four lock actuators.
Old Feb 18, 2024 | 02:03 PM
Ok, I see that now.
I suppose with the sunroof drains leaking, it is also possible that the grounds for the switches(under each front seat) could have both corroded at the same rate
Old Feb 18, 2024 | 04:39 PM
Very plausible
Old Feb 18, 2024 | 05:03 PM
If replacing the BCM made them stop working, I would be looking at the plugs and pins on the BCM; especially the white and white/black wires on pins #6 and #7 on connector C1 (the horizontal one on the lower right), those are the lock/unlock signals.
The difference between lock and unlock is a resistor in the buttons.
barnie121
Oct 24, 2014 11:55 PM
rash4843
Nov 11, 2013 12:08 AM
vlxk98
May 10, 2013 06:21 PM
jerry4155
Mar 12, 2013 10:22 AM
pyro panel
Apr 15, 2010 04:30 PM
