2006 HHR Intermittent Starting Problems
Old Jul 6, 2016 | 01:51 PM
Paquinr89's Avatar
Thanks for replies everyone. I will be taking the battery to get checked right after I get off work. I will let you all know how it turns out
Old Jul 6, 2016 | 03:49 PM
Paquinr89's Avatar
I just got the battery tested at my local autozone, and all tests came back 100% good on my battery and alternator. They used the tester that hooks on like jumper cables.
Old Jul 6, 2016 | 04:01 PM
Ok now on to checking ground wires and your underhood fuse box.
Old Jul 6, 2016 | 04:06 PM
Paquinr89's Avatar
Is there a simple way to check the grounding. I don't have much experience doing electrical work on my car.
Old Jul 6, 2016 | 04:45 PM
Eyeballs & fingers!
Old Jul 6, 2016 | 04:47 PM
Yes, eyeball the connection ( with safety glasses or googles in position!!)
Disconnect the ground at the battery to avoid sparks and power surges to the computers
A: wiggle connection
B: gently tighten ground lug nut
There are assorted sized ground connection fasteners, I suggest you start back near the battery
Now if there is any apparent corrosion you're gonna have to take the cable off and clean any junk out with a wire brush.
There is a ground under the hood just down and to the right of the oil filter housing
And one on the rad cradle on the engine side above the drivers headlight
Don has a great thread here
https://www.chevyhhr.net/forums/how-...cations-56504/
dadman503
Jul 15, 2013 04:03 PM
grannydeb
Jul 1, 2013 09:39 AM
Dyke67ny
Jun 27, 2012 10:34 PM
bculberson
Mar 19, 2011 06:51 PM
gksmith6
Aug 4, 2010 03:44 PM
