2006 hhr LT issues
Old Jul 17, 2022 | 09:50 AM
2006hhrlover's Avatar
2006 hhr LT issues
I have used this site for years but never joined as I usually found my answers just browsing,
482000 miles on my baby. plenty of issues over the years but no car notes for a long time so i fix and keep rolling.
My latest issue started when a car wash ripped off the antenna, I replaced the antenna base and the antenna but my xm did not come back on.
I was using this as an excuse to upgrade to a touch screen with back up camera and dash cam. However , when best buy put everything in , they say the unit powers up for a second and then goes out with no power.
They think the standard aftermarket kits they would use are not matching up with the power connections.
any suggestions would be appreciated.
Old Jul 17, 2022 | 12:19 PM
greg8453's Avatar
I'd find an installer that does it exclusively. When you have a place like Best Buy doing this kind of work they get lucky or they throw their hands in the air. They have no way of troubleshooting it. They may have installed it wrong.
Old Jul 17, 2022 | 03:35 PM
I suggest you have a look at the Crutchfield website! They have a trouble shooting area. Yes it could be the XM receiver is damaged from the water . But it could be BestBuy wasn’t the best choice!
Old Jul 17, 2022 | 04:53 PM
Just to clarify, the XM antenna is the rear antenna. Is that the one that broke?
Also, there are many variations of the rear antenna. Some are XM, some are not. Which part number did you install? (If it was even the rear that was replaced)
Old Jul 17, 2022 | 04:56 PM
The XM antenna is in the rear. The radio antenna is in the front.
The radio antenna has an amplifier in the inner side of the base. That is powered by the Pink wire from the radio. That wire also turns the power amp on (if you have one). I suspect they thought the pink wire was something else and hooked it up wrong. If these guys are professionals they should be able to RTFM for themselves. All of those adapters have instructions. Maybe they thought they were working on a PTCruiser.
Old Jul 17, 2022 | 06:20 PM
PulpFriction's Avatar
Yes. From the last few comments, we’re back to getting expert help, aren’t we. I can say from experience that with car audio it’s the installer, not the company. Inquire about the reputation of the person not the name on the door.
Old Jul 17, 2022 | 07:28 PM
There is nothing very special about an HHR stereo system that other cars made this century don't have. They are different from the pre-1996 cars.
Old Jul 25, 2022 | 02:21 AM
I replaced the front antenna. i just received the rear antenna and plan on changing it out on my next off cycle.
Old Jul 25, 2022 | 03:44 AM
Yes but there is something special about an incompetent’s ability to make a shambles of your car’s electronics.
fonque
Dec 27, 2020 05:13 PM
bfranker
Jun 22, 2014 07:19 AM
JAMIROBri
Mar 26, 2012 10:47 AM
lake
Mar 13, 2010 10:35 PM
Canadian HHR
May 13, 2006 09:13 PM
