2007 Chevy HHR LT Heat Blend Door Actuator
Old Feb 23, 2020 | 06:30 PM
Ronnie's Avatar
I am not really a mechanic. 📝 My daddy was a Certified Master Mechanic. I have been playing with tools since I was a toddler. I am learning as I go along.
I will definitely make someone a good wife one day. 😆
Old Feb 23, 2020 | 09:17 PM
Mods
Another thread in the "How To" forum that needs to be moved.
Old Feb 23, 2020 | 09:59 PM
done
Old Feb 25, 2020 | 05:44 PM
Ronnie's Avatar
I put the new intake air hose on this evening. Now a coworker told me one of my rear back-up lights is out. I swear my list isn't getting shorter guys!
Old Aug 2, 2020 | 10:44 PM
Ronnie's Avatar
Well, five months later and I finally installed heat blend actuator. I didn't take every part of me dashboard out. But I did take out the air bag. Gave me a little bit more room to maneuver my hands.
I have put everything back together and it works fine. But now I have a service light on that says service airbag. It's always something. 🙄😤
Old Aug 3, 2020 | 08:00 AM
You need to re install the airbag you took out the plug probably needs to be reseated.
Old Aug 3, 2020 | 10:26 AM
Ronnie's Avatar
I just woke up. Working nights is exhausting mentally and physically. So I just want to make sure I understand....
By reinstalling the airbag I am assuming you just mean to unplug the wiring and reconnect. I need to check the fuse to make sure it is good as well.
I have a couple of other questions but will start new threads to keep subject matters separate.
Old Aug 3, 2020 | 02:01 PM
Ronnie's Avatar
It looked like the locking mechanism is broke on the yellow connector., as they were no longer connected. I put them back together and taped with electrical tape to keep them snug.
The "Service Air Bag" light is out now.
Old Aug 3, 2020 | 03:19 PM
Awesome, problem resolved
Old Aug 3, 2020 | 04:43 PM
Ronnie's Avatar
Maybe not...I headed out the door to run an errand. "Service Air Bag" light came back on. I messed with the connector and it's back off again. I probably need a new connector.
The Passenger Air Bag light on the waterfall says OFF. It has always said OFF. But when I had started the car it flickered back and forth between OFF and ON. I don't see any switch to engage or disengage passenger air bag.
