2007 HHR 2.2 ECM Manual Transmission
Old Nov 10, 2011 | 08:25 PM
waldo38's Avatar
Unhappy 2007 HHR 2.2 ECM Manual Transmission
My engine light came and I went to have codes checked. They tell me I need a new ECM will be 900.00 to replace. Can I purchase from junk yard and install myself? The ECM is the silver box in front of my fuse box correct? I was told the car will not start if I purchase one without having it flashed. Is this correct. Seems like 900.00 a lot of money when I see new ones for 150.00 on ebay. Does the manual transmission take a different ECM then automatic? What years will work on my 2007 2.2 engine? Hate getting ripped off.
Thanks
Waldo38
Old Nov 10, 2011 | 08:29 PM
Snoopy's Avatar
Who told you that a new ECM was needed???? Not a GM dealer???
Additionally, why did they say you needed a new ECM? What was the codes pulled?
Old Nov 10, 2011 | 10:38 PM
All of Snoopy's questions X 2.
You need to take the vehicle somewhere else for a second opinion A.S.A.P., I think you're being set up to get screwed.
P.S. to the forum waldo38!
Old Nov 11, 2011 | 12:28 AM
Lucky's Avatar
x3 What kind of problem are you having with your car? ECM's don't fail very often but there are alot of aftermarket shops out there that blame the ECM first when they can't find the problem.
Old Nov 11, 2011 | 07:09 AM
waldo38's Avatar
codes were PO641, ECM detected the sensor 5 voly reference circuit voltage is higher or lower. Cause 661 Short circuit, 662 Shorted sensor on 5 volt cirruit, 663 Failed ECM. Code PO108 MAP, Cose PO106 MAP
Old Nov 11, 2011 | 07:11 AM
waldo38's Avatar
I can buy a new ECM for 100.00 dollars will the car start if I install or not? Where can I go to get the ECM Flashed? I need to start somewhere. I need my car for work. It is currently running but not good.
Old Nov 11, 2011 | 07:24 AM
If you get the proper ECM from a reputable source and make sure its cross checked and matches your engine, it should fire up after installation.
Now here's the big "BUT", you need to make sure the conditions that caused the original ECM to be "taken out" are corrected, if you don't you'll just kill another ECM.
A dealer can reflash the replacement ECM for you, the rates vary so you need to call first so you don't get a surprise.
Old Nov 11, 2011 | 09:27 AM
ChevyMgr's Avatar
Yes.
outdoordudley
Oct 29, 2013 09:13 PM
sti1imatic
Oct 7, 2011 09:47 AM
jmarines
Aug 29, 2009 11:22 AM
DMcGrew
Jan 12, 2008 11:12 AM
nabate
May 22, 2006 10:36 AM
